5-6 driven gear chipped
Old 03-09-2008, 09:18 PM
meatman's Avatar
Default 5-6 driven gear chipped
So we tore down my T56 for rebuild and while pulling off the 5-6 driven gear we chipped the edge of a tooth. Wanted to get some opinions on the severity of it. I would like to replace it but they are about $200 new. I am hoping to get a take off from someone for alot cheaper though.
I am guessing I could run it but it would prob make noise and maybe cause later failure. I dont think its worth the risk. Give me your opinions.....
Old 03-09-2008, 10:22 PM
thesource's Avatar
It will be fine . Its very common for this to happen when using a puller on the gear . My puller has a very wide jaw on it so it covers more of the gear and reduces the chances of chipping a gear .
Old 03-10-2008, 07:38 AM
meatman's Avatar
I am gonna call Amber at Six Speed Inc. today and see what she says....
Old 03-10-2008, 09:31 AM
thesource's Avatar
Why not do this in the 1st place then instead of posting on here about ???
Old 03-10-2008, 05:05 PM
meatman's Avatar
I thought I would get others opinions on it. Like yours
I decided to file the rough edges away and run it. Its just 5th gear so I will rarely use 5th and it wont see any hard use like if it was 1st or 2nd or something.
Old 03-10-2008, 05:17 PM
thesource's Avatar
The main reason you can get away with it is because the face of the gear is pretty wide . It allows the force to be distributed over a greater area . If the gear was extremely narrow , I would not suggest using it .
Old 03-12-2008, 01:44 AM
LSGunZ28's Avatar
This is what happened to me as well, when I tried pulling it off..
mine was severe I had to gring off all the teeth of the gear and use an air pressured hydraulic press to get it off... 15 - 20 tons of force to take that sucker off... we arent recommended to go past 10 tons of force.
the folloing year a classmate brought in his T-56, HONESTLY it just came off by hand..
Unbelieveable..
anyways I chipped a few teeth so I had to replace mine..
BTW I dont see how you chipped the top of the gear, unless Im forgetting how that gear goes on the mainshaft... Its been a year since Ive seen my T56 internals..
Old 03-12-2008, 09:27 AM
thesource's Avatar
Some of them slide off because they have wear in the splines . If the wear get too excessive , the splines on both the gear and the main shaft strip out .
Old 03-12-2008, 09:21 PM
meatman's Avatar
The gear is upside down in the pic.
Quick Reply: 5-6 driven gear chipped
