Notices
WTB: U/D pulley, Torque Arm, Adj. Panhard
Old 03-10-2008, 07:38 PM
its turbo time's Avatar
Default WTB: U/D pulley, Torque Arm, Adj. Panhard
Like the title says...If you've got a deal on an U/D pulley, Torque arm, Or Adj. Panhard bar LEMME KNOW!!
Old 03-11-2008, 10:39 AM
silverboy02's Avatar
I have a red adj. Spohn panhard. PM me it you are interested.
Old 03-12-2008, 08:28 AM
Wicked 1's Avatar
i have a tq arm it is a brm i dont have a crossmember for it it is 75.00 from bmr will sell for 200.00 shiped
Eliminate traction problems with the BMR Trak PakŠ. This design eliminates the transmission tailshaft stress by relocating the torque arm front mount. Shorter torque arm design moves the "instant center" rearward for improved weight transfer on acceleration. This kit consists of the adjustable torque-arm, a universal crossbrace, mounting hardware, and an anglefinder for adjusting pinion angle. Rear end mounting plates are made from strong, laser cut 3/8 " cold rolled steel. Equipped with a rear adjuster to allow on-car pinion angle adjustments up to 6 degrees for dragstrip tuning and a polyurethane front mount. Torque arm is made from 1.25" x .120" DOM tubing while crossbrace is made from 1-5/8" x .120" DOM tubing. Crossbrace requires welding and professional installation. Available in Black Hammertone or red powdercoat.
NOTE: Will not work with "diamond style" subframe connectors. Use of this product will produce additional road noise and is recommended for the serious enthusiast only. For questions please call or e-mail.
Part # TPU001 Universal Trak PakŠ
Old 03-15-2008, 10:57 PM
bump!
Old 04-28-2008, 06:59 PM
52172's Avatar
I have a red chromoly adjustable BMR TA pm if interested.
Old 05-18-2008, 07:30 PM
janders's Avatar
I have an adjustable panhard bar. PM me if interested
