engine vibe after vig.3200 tc installed??
Old 07-21-2003, 09:34 PM
pascal's Avatar
Default engine vibe after vig.3200 tc installed??
bad vibration at 22 and 3200 rpm.tc seems kind of soft,what do you check first.should a guy pull the verter and stick the stock one back in ??? any help thks.
Old 07-21-2003, 10:02 PM
Restricted User
2001 Pewter WS6's Avatar
Default Re: engine vibe after vig.3200 tc installed??
Pull the conveter bolts and rotate the converter 120 degrees and bolt it back up. It happened to me and this fixed it...
Old 07-21-2003, 10:07 PM
FrankSS's Avatar
u gotta make sure the converter is locked down good on the input shaft...
Old 07-21-2003, 11:07 PM
pascal's Avatar
thanks,if the verter is not in all the way is it ok to shim it with washers and longer bolts??
Old 07-22-2003, 01:53 AM
bigeller's Avatar
As long as the bolts aren't too long.. We made the mistake of using the stock bolts on mine with no washers.. Talk about vibration and noise! haha
