fms 24lbs injectors on a lt1
Old 03-13-2008, 12:05 PM
lt170chevelle's Avatar
Default fms 24lbs injectors on a lt1
ok i gotta pair of fms 24lbs injectors off of a 460 now if i put these on my lt1 wouldnt the fuel pressure difference make these close to a 30lbs.
Old 03-13-2008, 02:12 PM
StealthFormula's Avatar
If they are ran on the same fuel pressure as other ford vehicles that use the SVO 30's etc. which I assume so than they would only be like 25-25.5lbs.
Old 03-13-2008, 07:56 PM
rkinney's Avatar
I use the 24's, but the pcm is tuned for them. I forget the formula, but at gm fuel pressures they flow something in the neighborhood of 26lbs. That's what I use for my injector constant.
Quick Reply: fms 24lbs injectors on a lt1
