Need Help Please 4l60e
Old 03-14-2008, 10:12 PM
TODDS93T/A's Avatar
Default Need Help Please 4l60e
Ok heres my problem i have a 1998 s10 2.2 trans has no drive but will move if manual shft i have a trans out of a 1998 firebird thelook the same even the same converter i have to change the tail shaft but on thing is the shift link shaft that goes in the trans the one the firebird is short and does not accommodate the netural safety switch can this be remover with ease i can do anything motor wise but stil learing with the trans thanks
Old 03-14-2008, 10:46 PM
LS1Tech Sponsor
performabuilt's Avatar
Swap the linkage shaft and you will be set
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 03-14-2008, 10:49 PM
TODDS93T/A's Avatar
so they are the same trans thats cool but how do you swap the shaft from the pic ive saw it look like it has nut on the inside but i didnt know if it has any thing deeper inside thanks you
Old 03-14-2008, 10:56 PM
LS1Tech Sponsor
Thats it
__________________
Call 888-744-6542
