Battery Guage Problem
ok when i start up my car the guage on the dash is fine and after about 5 minutes of driving in traffic because of my school my guage goes down to about 10 when im just sitting there and it goes up when i press the gas (i guess you could say its acting like an rpm meter by the way it looks) and when i start it up later in the day it works perfectly fine. but i just replaced the alternator about 2 months ago what is the problem???
One quick checis to see what your battery and alt is putting out while the car is running if the gague and the battery have the same then you know that the gague is reading right.
But it could be the battery, Depending on how often you run your car or if you have anything that draws power while your car is at rest. Because it is normal for the battery to loose some power over time and then the Alt will charge it back up.
