4.56 gears not possible with '98 pcm???
I've got 4.56 gears in my new 9" rearend. In HPTuners, when I calculate the tire/gear ratio (26/4.56 = 5.46) and click commit it says invalid entry! It won't let me input anything lower than 6.00. Is there a way to make this work or is this yet another reason to despise tuning a '98?? I'd really like my speedometer/odometer to read correctly.
Ok, so the lowest gear ratio you can go with factory 26" tall tires is 4.33's. Any lower than that goes beyond the limits of the pcm. By my math, running 4.56 gears while the speedometer thinks they're 4.33's would leave my speedometer reading 4mph fast at 70mph (speedo says 74 when I'm going 70). Any math wizards wanna double check that? I could live with 4mph off if I figured that right. My head hurts.
