LS2 with Procharger in a 67-69 Camaro?
Has anyone here done it and what pulley setup did you use and what procharger bracket did you use.
I found out today that the Procharger GTO brackets won't fit.
Anyone running the F-body or corvette kits?
mines not a camero,but an A body-69 chevelle
i used the corvette front drive, and a d1sc w/8 rib conversion, with the vette procharger brackets-i have everything pretty well worked out, used an F body air intake, which i will duct thru the inner fender well where the filter will be mounted-i also used a procharger intercooler (super ebay deal) i hope to fire it up this week
also starting out with a carb, may switch to fi later, but i have experience with prochargers/carbs, and i am **** with computers
