crank hub pullier
Old 03-22-2008, 11:01 AM
C5042081's Avatar
Default crank hub pullier
what puller did u guys use to get the crank hub off?(3 claw) brand/part #
doing a cam swap and just want to have all the tools ready
Old 03-22-2008, 02:58 PM
94'BLKBRD's Avatar
I bought mine form Autozone.
Old 03-22-2008, 04:09 PM
That's MISTER MODERATOR
Paul Bell's Avatar
You'll need a long 7/16 X 20 bolt. Cut the head off, thread it into the crank. The puller will need to push on this bolt. It'll help if you dimple the center of the cut end of the bolt.
This is needed as the stock damper doesn't have an opening the size of the crank like standard SBC's do.
Old 03-22-2008, 04:21 PM
TimNJTA's Avatar
Somehow I found a long allen bolt with the 7/16x20 thread laying around that I used.
As for the puller, just the medium sized (I guess thats a size .. lol) 3 jaw from any auto store. Same sized on I use to pull the lower timing chain sprocket off.
Old 03-22-2008, 07:14 PM
ulakovic22's Avatar
I used a steering wheel puller. It's not set up right in the pic, but replace the stock bolt with the 7/16x20 bolt pictured in the first pic and it's will come right off.
Old 03-22-2008, 07:48 PM
StealthFormula's Avatar
Scott, my buddy has one of those pullers and I was gonna grab it from him tomorrow for doing another cam swap so if you want to borrow it its all yours.
Old 03-22-2008, 09:28 PM
C5042081's Avatar
kool ill let ya know , gonna see what my dad has around his shop first.
Quick Reply: crank hub pullier
