tranny issue
tranny issue
well i couldn't help myself and used my n20 the other day on the way home and well, the car shifted fine on the 1-2 but on the 2-3 it hit the rev limiter.
ever since then if i floor it the rpms shoot up and bounce off the limiter and it will not shift under full throttle. at part throttle it will shift but only at higher rpms. mods in my sig, i was only shoting a 50 dry with a window switch, converter is a fuddle 3500 2.0str. does this sound like a converter problem?
i had a light from an o2 that was out but i will check again tommarow.
under normal driving the car will shift but it is around 3500-4500rpms once the car shifts in to overdrive it drives normal. if i give it gas to try and get it to down shift it won't, the rpms just climb and will bounce off the rev limiter.
