wont hold oil
wont hold oil
Ok so i replaced the diff cover this week. I drove it for about an hour to see if it held and it did fine. Now i go outside after it sat for about a day and all the gear oil is in my garage. what should I do? I put rtv all the way around the gasket and torqued the bolts down to 25 ft/lbs.
10 bolt on a TA. The diff cover was all I changed and I used the correct bolts and washers sent from mac.
It was leaking before but I assumed it was because the diff cover was bent
