Stalling after burnout...
My car seems to act goofy after a burnout. I have it tuned pretty well with an open loop MAF tune, and I also have an SD tune I'm working on. Basically, the car runs great until I do an extended burnout at the track. When I roll forward to stage and it starts to surge and will die occasionally. Can someone point me in the right direction as to where to look in the tune to perhaps fix this issue? Like I said it runs great otherwise! Thanks in advance.
-Ross
-Ross
I had a similar problem and had to increase the airflow in the Throttle Follower in Gear table. I also changed the decay rate for the same so it wouldn't decay as fast. It takes time to get it right so it doesn't hang, but it should help.
