MSD box mounting ideas
I want to hear some different ideas with pics of locations where you guys are mounting your 6AL boxes...I would like to mount it inside the car but im open to anything, pics are appreciated...
Put mine in the glovebox. There is a rubber grommet with other wires running through it to the engine compartment right behind the glovebox. Made running the wires up to the power source and ground pretty easy. To run it to the coil, I had to run it along the firewall, then up along the intake. Worked out well.
