Mcleod adj master
Old 03-26-2008, 03:38 PM
Demonicbird00's Avatar
Default Mcleod adj master
when should you rebuild the master? ive noticed some clutch fluid coming out of the boot near the pedal
thanks
brandon
Old 03-26-2008, 04:51 PM
superslowjoe's Avatar
thanks
brandon
I think your answer is in your own question, if its leaking, fix it. I didnt and now I can't use the car at all,I need to rebuild mine as well.
Search for the post on the wilwood re-build kit.
Old 03-26-2008, 06:42 PM
alritey then lol.... why not buy the mcleod rebuild kit?
Old 03-26-2008, 06:54 PM
dam it... how come now i find out that the valvoline brake fluid is no good ...***....
gonna order a new rebuild kit and gop to the parts store and get reg brake fluid
Old 03-26-2008, 08:43 PM
John02SS's Avatar
I've had really good luck with GM brake fluid, and was told the same thing from Shane at Thunder Racing.
Old 03-26-2008, 09:08 PM
ill pick some up tommorrow, im gonna order a new clutch resivor (sp) w/ braided line and prolly the remote bleeder line too
Old 04-01-2008, 09:34 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
What's this about the valvoline brake fluid?? I'll do a search, but I thought it was a better choice than the factory fluid.
As for the Mcleod rebuild kit, supposedly it's more expensive and doesn't address the issue of the plunger sealing. I ordered the Wilwood kit from Jegs and it should be here today or tomorrow.
