Weird Voltage issue.
Old 03-29-2008, 02:27 PM
BJSS25's Avatar
Default Weird Voltage issue.
The car has a optima red top battery 2 and half years old, 160amp gm alternator 6 months old. My car will start fine, but after driving when you come to a stop light the voltage gauge bounces between 14 volts and 10 volts. But once I start driving it goes back to normal. The car doesn't sputter or die. The battery gets charged. I have a underdrive crankshaft pulley which is why I went with a bigger amp alternator. I have checked all the connections and grounds. Any other suggestions on possible fixes.
Old 03-31-2008, 04:18 PM
jmilz28's Avatar
Dealt with this myself. Could be the idle is not what the tach is saying, actually is lower than what it shows. This will make for a low charge at idle and cause what you are seeing, especially when you turn the AC on or the fans kick on.
Could also be the alternator going out. I lost 3 in 5 months, AC Delco. Good thing I got the lifetime parts and labor deal!!
Also check our battery cables, may be corroded inside the insulation from the factory battery.
Old 08-18-2008, 02:46 AM
ryan1428's Avatar
Did you find out the problem? Curious.
Old 09-13-2008, 01:09 AM
gm94's Avatar
Check this thread
https://ls1tech.com/forums/general-maintenance-repairs/981276-alternator-problem-please-help.html
