BS3 Wiring Shorting
BS3 Wiring Shorting
As some know the wiring is wayyyyyyyyyyyyy to long. Well talking with alot of people and give a few shops a call I have a clear path forward.
Simple thing is remove pins from connectors and cut to length and replace pins and insert back into connector.
Simple question is where do I find said pins???? I have searched on the interweb and I have came up with nothing.
When I say pins I mean- Terminals
I am told I can still use the same connectors. However for the cost it might be easier to just get new connectors as some are a pain in the but to remove.
Guys at Murrilo said they would only charge like $150.00 to do it so I might just have them do it to save me a headache
The terminal is 12124075 and is available from anybody that can purchase Delphi parts. One example company would be www.powerandsignal.com
Most connectors that use these terminals are pull to seat (push wire through connector from seal side--crimp on terminal--pull terminal back into connector. The little tang that hangs down will key the terminal in the correct position.
