shaft rockers
Old 04-02-2008, 09:04 PM
Apollo0526's Avatar
Default shaft rockers
will they fit under the stock valve covers?
Old 04-02-2008, 09:16 PM
DONAIMIAN's Avatar
what brand?
Old 04-02-2008, 09:18 PM
DONAIMIAN's Avatar
Although shaft rockers should not designed around stock covers. If you have the money go jessel.
Old 04-03-2008, 07:33 AM
KCS
Moderator
KCS's Avatar
I have heard that the shaft rockers that are designed to fit under stock valve covers (T&D specifically) have some design flaws in them which limits the lift you can use without running into problems. Erik (Racer 7088) has had some experience with these rockers. Find his name in the member's list and check his recent posts, you'll see what I mean.
Old 04-03-2008, 08:28 AM
Apollo0526's Avatar
thanks
