need exhaust advice, please chime in
Old 04-03-2008, 09:05 AM
qwickLT1WS6's Avatar
Default need exhaust advice, please chime in
i have a M6 dumdumdumdumdum with a bunch of boltons, currently the car has LT's to a ORY into a Flowmaster. I want to put true duals on it that will dump at the rear axle. The car will ocasionally see nitrous later on in the season, but will mainly be my DD. I will use two bullet mufflers: should I run 3 inch duals, or should I go down to 2.5?
Thanks for your help
Old 04-03-2008, 09:30 PM
can someone chime in?
Old 04-03-2008, 09:35 PM
simster571's Avatar
it depends on how much HP your pushing. I think that 2.5 inch duals are good for 500 HP, 700 for 3 inch duals.
you should be fine with the 2.5 inch, and have more clearance to.
Old 04-03-2008, 09:41 PM
BOLO's Avatar
If the car is going have more mods in the future,ie.h/c/i,n20,etc., then yes, I would opt. for the 3" piping.
Old 04-03-2008, 10:42 PM
thanks a lot guys
Old 04-03-2008, 10:43 PM
LT1
LT1's Avatar
My setup is 3 inch but its all up to you and your future mod's this link might help you diside.
http://www.lt1engine.com/techaids/trueduals.html
