Finally got the old heads off...
Old 04-03-2008, 06:58 PM
Bill Bowling's Avatar
Default Finally got the old heads off...
I am installing new Dart 205 heads with .040 head gaskets. This is my first time. What a job. I used the instructions from ls1howto.com. I found out I needed a fuel line tool after I already started the tear down. I also found out the Auto Trans dip stick had a bracket on the back of one head down low. That was a real pain to get too. The bracket bend but I did get it off. The other head had the two grounds and they were no problem. Now to clean everythin up tomorrow and start putting it back together after I clay the PTV clearance.
Bill
Old 04-03-2008, 10:13 PM
Gun5's Avatar
gonna be doing this soon with some 5.3's and a 228/232 can't wait
what tool did you get for the fuel line a plastic 3/8?
Old 04-03-2008, 10:55 PM
Fratsit's Avatar
Bill,
Best of luck with the build. I did the same and also flycut back in December. Other than the flycutting, the most tedious part was prepping the deck surface. I highly recommend using the rolled up paper towel method they show in the tutorial to get the coolant out of the bolt holes. It works like a champ.
The head swap has been the best mod to my car so far. You'll like it.
R/
Frat
Old 04-03-2008, 10:56 PM
sworaz's Avatar
Good luck with it, hopefully you end up with some stout numbers.
Old 04-04-2008, 08:09 AM
I used a 5/16" O'Relly's part number 39410.
Bill
Old 04-04-2008, 08:12 AM
lastcall190's Avatar
Good to know that the LS1howto.com guide wins again... I am tossing around the idea of doing heads either toward the end of summer or over winter (I'll have a sizeable fund saved up for then, should something BAD arise). Congrats on the successful tear down. Any pics?
-J
Old 04-11-2008, 05:50 PM
Car is running great. I will get it dynod at G12.
Bill
