FAST 90/90 or FAST 92/92
Old 04-05-2008, 01:36 PM
LT1dude's Avatar
Default FAST 90/90 or FAST 92/92
I will be doing shortly a TSP PRC 2.5 5.3 setup on my LS1, with 150 shot in mind. What intake would be better? 90/90 or 92/92, and why did FAST just up it two mm?
Old 04-05-2008, 02:10 PM
Benny Blanco's Avatar
Fast 92/92.......................BB
Old 04-05-2008, 02:11 PM
I take that back a fast 90 with a nick Williams 90 thats an awesome combo....BB
Old 04-05-2008, 02:25 PM
Internet Mechanic
BlackScreaminMachine's Avatar
The 92 was just a revision, the extra 2mm does really nothing but they have now stainess hardware and other things. I would do a search
Old 04-05-2008, 03:21 PM
Screamin_Z's Avatar
from what I've seen the shops say on here they no longer make the 90 intake so u might be hard pressed to find one. just get the 92 and like stated above there isn't much of a difference, juse 2mm more of an opening.
Old 04-05-2008, 03:32 PM
Martin HD-28's Avatar
The latest GM high performance mag claims gains of 5% increased airflow between the 92mm over the 90mm fast throttle body.
Old 04-05-2008, 03:47 PM
AU N EGL's Avatar
Really? I though there was no difference.
Dont think Fast makes the 90/90 any more, All 92s now
Old 04-05-2008, 06:30 PM
Kingc8r's Avatar
^ Yea everywhere that I've called doesn't sell them any more
Old 04-05-2008, 06:33 PM
Fabrizi's Avatar
Check craigslist/ebay for ppl selling those things, get killer deals compared to what they went for new.
Old 04-05-2008, 06:40 PM
Moderator
davered00ss's Avatar
The 2mm does not make a big difference. The big thins is the stainless hardware. No more rusting within 2 weeks. Also the TB gasket is better. The biggest improvement is the MAF sensor hole is the right size now.
Old 04-05-2008, 06:42 PM
Moderator
I'm also sure there are still shops with the 90's still on the shelf.
Old 04-05-2008, 06:44 PM
AU N EGL's Avatar
If you plan on Porting them, dont buy used ones.
Old 04-05-2008, 06:48 PM
TransAmcoupe98's Avatar
That intake will be a good mate for nitrous. I would just buy a used ported one off someone here.
Old 04-05-2008, 06:50 PM
Moderator
Get one from Vengence. I would not get one if it was not ported by some one with a reputation for porting them.
Old 04-05-2008, 08:18 PM
allngn_c5's Avatar
+1 to Ron. Don't forget about Tony Mamo though. Both gentlemen do one hell of a job.
Old 04-05-2008, 09:54 PM
cdavis01's Avatar
I just got done doing the same setup your doing and it feels great.
Old 04-05-2008, 10:30 PM
snake charmer's Avatar
the larger it gets the more area it gets . looking at area and if my math is right a circle is pie x radius squared . so 90mm tb would be 6358.5 a 92 would be 6644.24 . if you go back to look at a 91mm it would be close to 6500.59 . so 90 to 91 is an increase of roughly 142 . the increase from 91 to 92 is a little more than that being 143.65 .
so this means since it it just two more mm it is not equal to the difference of the increase of one at a time . every mm adds that and then some even though it might not be a whole lot more .
Old 04-05-2008, 11:56 PM
merlinn's Avatar
just get the one that you can find cheaper. thiers not much of a difference
Old 04-06-2008, 12:04 AM
408z28's Avatar
I cant wait til the FAST 164mm comes out !!! It will be so cool!!!! Ill flow .0003% more air and go .001 quicker at the track!! It will be worth all $1500 ill have to pay for it!! WTF are some people thinking??
Old 04-06-2008, 12:17 AM
bayer-z28's Avatar
^ Think of the TB size this way, PatG was still pulling vacuum at WOT on one of his setups... The restriction is the TB size.. The CARB guys go instant 0 vacuum at WOT.. think of the opening size difference. It's basically a metered orifice, or a restricted opening. Lets try to eliminate as much loss as possible. I think if they did a slightly bigger TB/Intake design, they could get pretty close to 0 vacuum @ WOT.. As if the 90/90 isn't big ENOUGH, tho..
On a side note; The price on the FAST 90/90's came WAY down!! :shock: I'm thinking of getting one for the H/C swap this month..
Quick Reply: FAST 90/90 or FAST 92/92
