02 Sensor install
Old 04-07-2008, 01:34 AM
The_Wretched's Avatar
Default 02 Sensor install
Any links to how to install 02 sensors?
Thanks guys.
Old 04-07-2008, 01:47 AM
LT1-DAN's Avatar
They just screw into the exhaust manifolds/headers and plug the connector into the factory harness.
Old 04-07-2008, 02:24 AM
new to LS1's... how many are there?? and what other options can you do that work just fine?
do you have to use GM OE??
Old 04-07-2008, 02:39 AM
LT1-DAN's Avatar
You have 2 upstream and 2 downstream. Yes, the GM ones work the best.
Old 04-07-2008, 07:48 AM
Save the manuals!
wssix99's Avatar
You'll also need to apply anti-seize compound to the sensor threads before you put them in. (If they have been previously used.) New sensors should come with the compound pre-applied.
Without anti-seize, they will fuse to the pipes when things heat up.
