question about fbody fuel rail, truck coil packs
Old 04-07-2008, 04:48 PM
need ls1 not wankel's Avatar
Default question about fbody fuel rail, truck coil packs
Hi I am just looking for a quick answer here, I searched but could't find an answer. I have a 5.3 with a ls1 intake, injectors and a f-body fuel rail, my probelm is the fuel rail fuel input hits the truck coil packs, if I unplug the harness from that coil pack I can at least sit the manifold down right to bolt it down. Can i just bend the fuel input to clear the taller truck coil packs. I am putting a 350 dollar engine in a 400 dollar car so i would prefer not go with f-body coil pack or a aftermarket fuel rail. Thanks in advance
Old 04-07-2008, 04:53 PM
72chevelle6.0's Avatar
yes you should be able to just bend the inlet up to clear.
Old 04-07-2008, 07:11 PM
SheldonZ28's Avatar
on my iroc-z
Old 04-07-2008, 09:05 PM
ok thanks for the quick info guys
Old 04-08-2008, 09:06 PM
green28's Avatar
Thats good to hear, now you just gotta find some intake bolts.
Old 04-09-2008, 06:00 PM
99blancoSS's Avatar
You could relocate the coils as well. I make a kit for it and will make any length wire you need for a total custom install.
Old 04-17-2008, 06:25 PM
GTA91's Avatar
I'm having the same problem right now... thanks for the info. I guess I'll just bend the fuel rail inlet.
Quick Reply: question about fbody fuel rail, truck coil packs
