brake upgrade question
I've never heard of TT2 wheels. What type of dimensions are they.
The SSBC Tri-Power or Force 10 4-piston require a 17 inch wheel. If you are interested in those let me know because I am a dealer for them.
SSBC Tri-Power. Is a 3-Piston Billet Aluminum Caliper. Uses a one piece SSBC Slotted 13 inch brake rotor. Includes all hardware brackets, SS lines and pads. Bolts to your stock spindles. $1148.00 for the kit.
SSBC Force 10 4-Piston Billet Aluminum Caliper. Uses the same one piece SSBBC Slotted13 inch rotor. Includes all hardware, brakcets, SS Lines and Pads. Bolts to your stock spindles. Includes powder coating as well. $1279.00 for the kit.
Minimum wheel size is 17 inches. You shouldn't have any issues with these mounting underneath your wheels as long as your wheel offset is stock.
Here are some pictures of my setup up with the 4-piston kit. Note that those are my double drilled and slotted rotors. They don't come from SSBC that way.
C5 setup will fit under 17" TT2, but you will need a spacer (1/4" I *think*).
