Power Window not going all the way up.
I've had a problem with my drivers side power window not going all the way up for over a year now on my '98 Trans Am. Usually when I roll it all the way down, it will slowly go back up and stop about 75% up. After waiting a couple minutes, I'll try again and it eases up a little bit and repeating the process until it finally goes all the way up. Does anyone know what the problem could be? And/or how to fix it?
Thanks.
Thanks.
You think you are the only one?
Crappy motors. Check ebay. They are super cheap. Not a big install. Mine does the same thing. I am just waiting on the part. Dealership could not "replicate" the problem while it was under warranty. The whole thing is hit or miss. five minutes later it works fine.
Thanks. I see that the power window motors are pretty cheap on ebay, so it's worth giving that a try.
