LS1 without power steering on 240sx
Old 04-09-2008, 12:38 PM
wajouba's Avatar
Thumbs down LS1 without power steering on 240sx
Hello, I've installed my LS1 on the 240sx, and I can't find a damn Power steering thing for the LS1... in lebanon this is the only LS1 availible and I found it on a Saudi Car that Crashed, everything else is a DAMN LT1... So my question is, can I bypass the Power Steering on the LS1 and continue without it? cause my only problem is the CRANK PULLEY, I find the belt not really going around the crank pulley well... its like a little more than 1/4 of the circle... not half of the crank pulley is covered by the belt, only a little more than 1/4...
and for the pulley on the alternator Bracket... we can change it with a another one that has a grained surface instead of the flat one...
So what do you guys think? cause theres no way I can find a damn LS1 power steering assembly here... and if anyone has an idea if another car has the same Power steering assembly please give me hints... im in NEED...
Old 04-10-2008, 01:19 AM
wajouba's Avatar
Anyone? I just need to know whether another cars power steering pump and reservior would fit my 98 Camaro LS1...
Old 04-10-2008, 09:57 AM
LS1TECH Sponsor
Carshopinc.com's Avatar
Can you post up a picture of your current configuration?
Old 04-11-2008, 07:16 PM
wajouba's Avatar
my engine was out of a wrecked camaro... and the power steering assembly wasn't with it... what picture do you want exactly? I have a couple for the engine... maybe you can tell me whats missing from the power steering part... thanks...
Old 04-11-2008, 07:29 PM
wajouba's Avatar
Question
This is a picture of the engine in the car... with nothing for power steering... I wana know what am I missing exactly? is there a bracket like the Alternator? or only the resivor and pulley..?
Old 04-11-2008, 10:14 PM
jw33's Avatar
the pump bolts directly to that bracket that's on the head already. You could get a power steering pump from the parts store for a gto maybe and make a mount for the fluid res. I say the gto because it has a remote res. and you could put it pretty much anywhere above the pump and it should work....
Old 04-12-2008, 03:40 AM
wajouba's Avatar
thanks jw33, I thought I was missing the bracket also... but what am really asking is would a trail blazer's or envoy's power steering assembly work on my car? one of the more common cars to find... cause here in my country "Lebanon" we don't have 5.7 sport cars... all they tune are BMW's nothing else... so will anything from any other car bolt on to my LS1...? (exclude: GTO, Firebird, Camaro, and Holden) im asking about the Vortec engines...
Old 04-12-2008, 06:03 AM
whiteseven's Avatar
Why do you need it? It's going to end up being overpowered and twitchy anyway unless you can get an adjustable pump like a TurnOne pump from the states.
I personally don't use it in my swap (Rx-7) because the manual rack turns fast enough for me. Plus I've heard too many horror stories about no steering feedback at all because of too much line pressure.
Old 04-12-2008, 09:18 AM
IOwnCalculus's Avatar
The accessories for these engines are highly individualized - internally, the pump from a TrailBlazer / Envoy is probably the same, but the truck accessories are set up for a completely different depth so using one of those would put the pulley out of alignment with the rest.
I can't imagine it's that hard to get a Camaro setup shipped from the US.
Old 04-12-2008, 11:49 AM
eastcoastbumps's Avatar
Have you driven it without P/S yet? You may find that its not all that bad. I didn't have power steering in my RX7 and it was fine.
Old 04-12-2008, 03:12 PM
wajouba's Avatar
but if theres no PS pulley, the belt will be upside down on the Alternator Bracket... So the braided part of the Belt on a smooth surfaced pulley will eat it up...
PLUS, the belt will not be holding the Crank pulley firmly, what I mean is that usually the belt is wrapped around the crank pulley about half way... without the PS, its nearly 1/4 wrapped around the Crank pulley isn't that not safe....?!
Old 04-13-2008, 12:13 AM
Run it like this with a 52.5" six rib belt:
Thats the way I run mine and I don't have any problem. You can also get a ribbed idler pulley from http://www.hotrodlane.cc/ and a 54.25" six rib belt Gates part# K060535 then run it like this:
Old 04-13-2008, 04:36 AM
wajouba's Avatar
the second way is how I ran mine but the thought of seeing the crank pulley only that much in contact with the belt sounded a little unsafe to me... so did the water pump pulley... but If you tried it I guess it works...
Old 04-13-2008, 08:16 PM
icantdrift's Avatar
the stock f-body pump works great with my factory nissan rack. quite a bit smoother than with the stock ps pump, definitely not twitchy.
Old 05-14-2008, 12:44 PM
wajouba's Avatar
damn the civil war started here in lebanon and I can't even go down to where my car is located...
Old 05-15-2008, 07:58 PM
Pop N Wood's Avatar
Keep your head down. Can't have one of the few Chevy guys in Lebanon catching a stray bullet.
Old 05-17-2008, 01:16 AM
aziza z's Avatar
Kinda off topic but does anywhere I can get those chrome pulleys pictured here?
Old 05-17-2008, 01:55 AM
StngKlr's Avatar
You dont need it, but like the guy above said......
And I think that answers that question too.
Old 05-18-2008, 02:42 PM
wajouba's Avatar
At last they controlled the situation and took the politicians to Qatar (a country in the gulf) to lead them to a common ground... I hope I can go tomorow to check on the car...
Old 05-18-2008, 03:07 PM
00SilverWS6's Avatar
My motor I bought is missing that idler pully, and Im not running power steering. So I would like to get that 6 rib idle pully from them but cant find it on the site at all.
Quick Reply: LS1 without power steering on 240sx
