I need front control arm bushing advice!!!!
Old 04-09-2008, 08:21 PM
KILLER-LS1's Avatar
Default I need front control arm bushing advice!!!!
hey, im about to install my hotchkis lowering springs and energy suspension bushings, and i was wondering if anyone had any tips for removing the front a arm bushings??? thanks for the help
Old 04-09-2008, 10:26 PM
KILLER-LS1's Avatar
please help me out guys, im planning on doing this in the morning!
Old 04-09-2008, 10:29 PM
Sinister95Z's Avatar
The bushings need to be pressed out and also pressed back in. You may be able to get the old ones out with a torch. Either way, it is easier to just find a shop that will do it for a decent price.
Old 04-09-2008, 10:40 PM
KILLER-LS1's Avatar
ya, i dont have a press, so im going to use the torch method. and im doing this by myself. any other advice?
Old 04-10-2008, 12:04 AM
02Z28LS1's Avatar
when installing the new bushings, you can probably get two thick, large washers and a long bolt that fits the hole of the bushing, then just crank down on it with one washer on each side of the bushing socket to squeeze it in there. just use a tiny dab of lithium grease to help persuade the bushing to slide in a little easier, and take it slow.
Old 04-10-2008, 12:07 AM
KILLER-LS1's Avatar
im assuming u are talking about installing the new bushings.... my main concern is getting the old ones out... or am i just being over paranoid??
Old 04-10-2008, 06:44 AM
02Z28LS1's Avatar
you can use any method of getting the old bushing out......hammer/chisel, torch, dremel tool, etc.
just be sure not to heat the actual metal itself too much if you use the torch, and you should be ok.
Quick Reply: I need front control arm bushing advice!!!!
