Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
LS7 lifters in GEN I SBC?
Old 04-12-2008, 09:15 PM
In-Zane Moderator
ZONES89RS's Avatar
Default LS7 lifters in GEN I SBC?
I heard they will work in a GEN I with OE roller (87-98), is it true or BS? If so i need to buy some but till somone verrifys this i will doubt it.
Old 04-12-2008, 09:21 PM
zjt
zjt's Avatar
I know that they're listed as the replacement for all LT1 and LT4 engines
Old 04-12-2008, 09:23 PM
Shawn @ VA Speed's Avatar
yes they do work-really good as a matter of fact,i use the **** out of them in our 383's
Old 04-12-2008, 09:24 PM
In-Zane Moderator
ZONES89RS's Avatar
K, i was wondering, the stock 87-98 lifter have the issue of spinning on a cam with lift excess of 530 lift sometimes, this is something i do not wanna have to worry about.
Old 04-13-2008, 05:10 AM
1970camaroRS's Avatar
I have not heard of an issue of spinning on the cam. That would mean the OEM dogbones and spider failed, or the square portion of the lifter became a circle. Either way I don't see that happening. The only worry I've ever heard of with the OEM roller is that the can fail under high lift and spill their guts all over the inside of your motor.
Old 04-13-2008, 02:57 PM
In-Zane Moderator
ZONES89RS's Avatar
Well, with a higher lift cam the base circle is what is said to be lower to the point of the lifter dropping too far.
Quick Reply: LS7 lifters in GEN I SBC?
