oil feed and return PARTS LIST
Old 04-13-2008, 12:13 PM
SaultysHuggerSS's Avatar
Default oil feed and return PARTS LIST
Just wondering is someone had a parts list of supplys used to oil feed and return for a front mount turbo? THANKS
Old 04-13-2008, 01:33 PM
Josh@KY-Turbo's Avatar
Oil Drain Parts.
(3') of -10 stainless steel braided hose
(2) -10 AN Straight hose ends
(1) -10 Oil pan adapter
(1) -10 X 1/2" NPT adapter
(1) billet aluminum T3/T4 oil drain flange.
Oil feed line are Pre-made High pressure line. Usually -3 or -4 and fave fitting for 1/4 NPT fittings.
Old 04-13-2008, 05:29 PM
thanks josh big help i been looking around and couldnt find this stuff
Old 04-13-2008, 05:56 PM
mightyquickz28's Avatar
I have the -10 oil pan bulkhead welded in already but I need all the other itemized items. I assume you sell this stuff? If so, how much for all but the oil pan bulkhead/adaptor shipped to Houston, TX?
I have a Turbonetics T76 for my LT1 and it's frontmounted so I suppose the 3' of line will work. Click on the link below to see the layout of my hot side and the mounting of the turbo if you want to make an educated guess on that length. The bulkhead adaptor is positioned at the top/front/right (when facing the Harmonic balancer). The pan was originally setup for a Vortech S/C so the position of the drain adaptor is commensurate with that kit.
http://www.taekwondoplus.org/z28/Tur...boHotparts.htm
Originally Posted by Josh @ KYTP
Oil Drain Parts.
