Heads?
Heads?
Two part question, I want to get AFR's 205cc's... the thing is I want to know what the stock combustion size is so that I may retain stock Compression ratio once they're installed. The second question is if I buy pre-assembled heads from AFR do I have my choice of valve train brands? I want to get Yella Terra Lightweight roller rockers, (I would also like to know stock roller rocker ratio?)
thanks guys.
thanks guys.
AFR is a great place to get the YT UL's, I got mine from Tony. Your best thing to do is give Tony Mamo a call at AFR and let him explain it all to you so you dont get convoluted info on here. 1.7 for an ls1 , off the top of my head yes to comression question but check with Tony to be accurate, great guy will take care of you and explain it all.
The stock rocker ratio is 1.7..I suggest you call Tony Mamo at AFR and he will be able to answer any of you questions concerning his product ... you are always better off going to the vendor with your questions..nobody will know more about it that he will.
