Whats The Best Aftermarket Maf?
Old 04-17-2008, 12:54 PM
bad2dbone's Avatar
Default Whats The Best Aftermarket Maf?
I Need 1 For My 92/92 Fast Intake & Throttle Setup
Old 04-17-2008, 02:11 PM
trans2000am's Avatar
SD tune
Old 04-17-2008, 02:20 PM
brandon619's Avatar
Originally Posted by trans2000am
SD tune
That is what I'm thinking. None at all.
Old 04-17-2008, 02:57 PM
bad2dbone's Avatar
Sd Tune Wats That? & how do u do that and what is it? where do u buy it?
Old 04-17-2008, 03:27 PM
Jimmy P's Avatar
Its a Speed Density tune. You would need to purchase a 2bar or 3bar Map sensor, depending on your application, and get rid of the MAF. Your tuner should know how to tune for it.
Old 04-17-2008, 03:40 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
if you are planning on keeping the MAF tho, just use a stock one. There is no way an aftermarket MAF will be any better than a stock one.
Old 04-17-2008, 03:47 PM
Slvr00Bird's Avatar
+1...
Old 04-17-2008, 03:52 PM
DanWS6's Avatar
How well does a speed density tune handle elevation change? I drive at about 5600 ft normally, but if I take the car up to the mountains I can hit 8000ft.. hell even 10000ft on some of the passes.
Old 04-17-2008, 05:32 PM
SS101's Avatar
from what i hear, SD is kind like a carb when it comes to changes in atmosphere. you have to get the car retuned for extreme elevations and climate changes (i.e. every season if its not a summer only car)
thats why i plan on going MAF, the lingenfelter 100mm MAF is my choice btw.
Old 04-17-2008, 05:41 PM
dreamls1's Avatar
Do you have to keep the MAF? How would you get rid of it?
Old 04-17-2008, 06:02 PM
bad2dbone's Avatar
i dont have 1 doing a engine swap on a 95 ta to a ls2 got everything just thought i would buy a aftermarket 1
Old 04-17-2008, 10:04 PM
DanWS6's Avatar
That's what my understanding is as well which makes it seem like a really unreliable tune.
Old 04-17-2008, 10:10 PM
Websy21's Avatar
You are wrong, if tuned right SD is way better and will compensate for temp and elevation changes. Research it some more, FWIW, all the Dodge Hemi's come factory with SD tune's!
Old 04-17-2008, 11:31 PM
Z06PSI's Avatar
Wow there is a lot of mis information in this thread.
? for the thread starter. Are you maxing out your current MAF? I am going to guess no. No need to change unless you are just trying to increase physical size from the stocker. Get a GM parts Z06 MAF and have somebody tune it to the car and leave it alone until you max the table.
