Procharger Power #'s
I hate to do this but im going crazy I'm heading to the dyno next Friday the 25th, what kind of power do you think I will be putting down????
1999 Camaro SS
6 speed car
Tex oz700
347 LS1
FAST 90mm intake
PTM 90mm tb
Patriot stg II LQ9 heads
COMP pushrods
EPP blower cam (232/240 .595/.608 on a 115)
Melling HV oil pump
JP timing chain
Hooker lt
True duals
Procharger P-1sc @ 8psi
Mototron 60lb injectors
walbro 255 pump
4:11 gears
The car has been street tuned. What should I see on the dyno
Troy
1999 Camaro SS
6 speed car
Tex oz700
347 LS1
FAST 90mm intake
PTM 90mm tb
COMP pushrods
Melling HV oil pump
JP timing chain
Hooker lt
True duals
walbro 255 pump
4:11 gears
Troy
Its got a rough idle , needs 3000ish stall on autos for streeting. But in a 347 its pretty drive-able. This cam was designed for the 347in motor to peak around 6500ish depending on heads and other variables.
If you plan more cubes, we have a few other grinds and/or custom grinds for a solid performing cam.
Troy
I would definatly start shopping for a forged bottom end. A 4.0 pulley is going to boost this thing pretty well, with heads and cam wow. I would guess 600+ as far as hp goes.
Remember, to make the bottom end live, run good gas when beating on it. No hot lapping and get a safe tune!
Troy
Hit the dyno yesterday! My base run showed 400rwhp/466rwtq. Vince from Trifecta Performance did his thing and when all was said and done I came home with 565rwhp/503rwtq. There is plenty more power left in it but we were runing out of fuel. Guess im going to install a dual pump set-up or something. After this issue is solved I should see over 600 easy. So all in all I walked away with an extra 165rwhp for the day. I was hoping to see between 500-600 and I got just that.
Troy
Troy
Troy
Troy
Thanks
Troy
