Clutch options for turbo setup
Old 04-19-2008, 03:45 AM
xxrillixx's Avatar
Default Clutch options for turbo setup
ok ive been searching for a few hours now and cant find what im looking for.
I need a clutch that will handle my 600+ whp/600+ wtq turbo setup. I have the Spec 3 (from specs website: stage 3 - 700 ft lbs tq capacity - 3800 psi pressure plate) but when the car is in boost, it is slipping with the high end torque in the higher gears. The clutch does have probably 20k+ miles on it, but i want to make sure the new clutch can handle it with a bit of life (15K-20K miles). I LOVED the Spec 3 with my previous setup (4.10's, 315Dr's, mild bolt ons)... but now with the 3.23 gears and turbo, its not holding up.
Ive been looking up textralia's... but i cant find what the exo-skel or the OZ700 ZGrip support as far as tq. Which would be better when in full bost in higher gears? The exo-skel has a smalle surface area, so would the OZ700Z be better? Or does the exo-skel still grip better?
Other options? (please include part numbers if possible)
Prerequsite's:
- Daily drivable (95% street - 5% track) I do like to autocross, but not often (3-4 times a year)
- reasonable cost
- decent life (15k-20k miles)
- very strong grip (especially higher rpms & higher gears)
I guess ill make some calls on monday... I guess im just too **** about stuff. lol. Thanks for any help!
Old 04-19-2008, 04:16 AM
xxrillixx's Avatar
Other options ive found:
Spec3+ - 850 trq ($600)
Spec 4 - 700 trq ($450)
Spec 5 - 1200 trq ($550)
Mcleod Twin - 1200 trq ($1000)
but im afraid to go Spec... even though i had a good experience with the Spec3, ive seen a TON of people have problems.
Old 04-19-2008, 06:29 AM
LS1Tech Sponsor
Slowhawk's Avatar
You'll need a twin disk clutch to hold that power for a long time and drive good on the street.
Old 04-19-2008, 12:18 PM
slayerized6's Avatar
spec measures hp and torque at the crank. look into getting a twin disk clutch setup
Old 04-19-2008, 01:01 PM
xxrillixx's Avatar
Who offers decent priced twin disk clutches?
I just talked to byunspeed... he said the exo-skel is not what i want... and the Z grip would probably do. Or the Mcleod Twin disk rxt (1000hp).
