Vibration
Vibration
First off, i was getting some bad vibration during hard acceleration in third and forth gear, but not all of the time. Sometimes it would sometimes it wouldn't. I never could figure it out. Saturday i installed Koni 4/4, Strano springs and sway bars, UMI Adjustable Panhard bar and a UMI non-adjustable TA with the relocating bracket. Now i am getting bad vibration all the time at 50mph and up, only when im on the gas. If i let off the gas it goes away. Its bad enough that i can't drive it over 50. Any thoughts? Thanks
LS1Tech Premium Sponsor
You may want to check it anyway. As somebody already mentioned, u-joints may be a possibility, however you also mentioned that it worsened after you put the lowering springs and TA on. You might have gotten into a situation where the pinion angle is out of the acceptable range now.
2 days ago my car was shaking terribly going 90 + when i'd get on the gas, like you're describing. Today i took my car in to discount tires bc there was a screw in my back right tire and i needed a patch, i just told them to balance the tires. I'm going 100 on the way home, no shake. Could be as simple as that.. i dont know though
Well i talked with Sam Strano and he had me try a few things to narrow it down. He feels it is probably my pinion angle. I ordered an Adjustable TA, Hopefully that will cure my problem. My Hats off to Sam Strano for AWESOME customer service.
