5.3 tach output signal
Old 04-20-2008, 04:00 PM
gimmie11s's Avatar
Default 5.3 tach output signal
setup-
2003? 5.3 lm7 going into a 81 swb chevy truck.
This will be a carbed setup and i bought the motor complete from truck intake to oilpan BUT WITH NO WIRING HARNESS.
question is-
where do i tap into for my tach signal? I want to run an aftermarket tach. Also, one of the wires i need to hook up for the MSD 6010 is a tach signal.
i'd assume i could get one off of the coil pack but which cylinder and what color?
yes i tried searching.
help!
Old 04-20-2008, 06:20 PM
gimmie11s's Avatar
nobody?
Old 04-20-2008, 06:37 PM
1987earthquake's Avatar
tach signal comes from pcm.. white wire
Old 04-20-2008, 09:21 PM
gimmie11s's Avatar
you missed the part about being carbed.
you also missed the part about no wiring harness.
thanks anyway
Old 04-20-2008, 09:39 PM
fastrucken's Avatar
the tach signal wire from the 6010 is a tach signal output, not input and will run your aftermarket tach. just hook the box up to your cam, crank, map sensors, hook up your coils, hook up the 12v and it should fire right up.
Old 04-21-2008, 03:46 PM
gimmie11s's Avatar
you know what... i slept on this problem and figured that the 6010--once it's all hooked up--should not need a tach input and that the wire is actually an output.
you confirmed my thoughts!
thanks so much.
dd
Quick Reply: 5.3 tach output signal
