Suspension & Brakes - ABS Delet
View Full Version : ABS Delet
FASTRAKTA
04-20-2008, 06:19 PM
Ok guys here goes. I have a 02 WS6 TA.I put in a 9" Moser rear with out the
4 channel option. I decided I would get rid of the ABS all together,so I got the ABS Delete kit. I've helped a friend with his kit that was on a 95 Z28, seemed pretty straight forward. We put it in and everything was fine. On mine not so lucky. With the ABS on mine the brake light stays on,ABS in-op,is on ,and a check vehicle light is now on.I know that the computer is not getting a signal so that is why the ABS light,and probably the service vehicle
light. Can I just jump these wires to trick it into thinking it has the ABS unit.
Or do I need to get someone with a HP Tuner and do it that way.Is there any one else who has done this and had the same problem. I will call up the company that I bought it from and see what they say. Just hoped that someone else did this.
95GreenZ28
04-20-2008, 06:21 PM
I did mine on my 95 and the brake light and abs inop light stay on. Never had the service engine light come on for that though
FASTRAKTA
04-20-2008, 06:33 PM
No its not the service engine,its the service vehicle light.
FASTRAKTA
04-21-2008, 08:21 PM
Well called up the company that makes the ABS Kit. Found out that the 98 and older models are much different then the 99 to 02 models. Although the kit fits all models there are some board differences, and unit. He gave me some pin numbers to jump the wires but he wasn't sure about the 99 and up models. Is there anyone out there that has done this set up on a 99 to 02 F-body.My last option is unplugging the warning lights in the cluster panel. Please is there anybody out there
2002_Z28_Six_Speed
04-21-2008, 08:59 PM
You could pull the front cover off the abs and plug that into the car. That would turn off the service vehicle light.
FASTRAKTA
04-22-2008, 08:55 PM
Ya did that the Brake light now stays on. I got myself into a mess it looks like. Thanks
