The making of a low 10 second street car.
I finally decided to try and get crazy on the mods im doing to my car. I ordered TEA 5.3 Heads, Comp 224/228 .581/.588 112lsa Cam, Chrome Moly Pushrods, TSP Ported Oil Pump, Rollermaster Double Roller Timing Set, Combination Motorsports Stage 3 4l60, PA Tubular K-Member, PA Tubular A-Arms, PA STB. Im planing on ordering a Walbro 340 pump, Yella Terra 1.7's. I already have a Vigi 2800 im getting done up to a 3600, BFG DR's, Headers w/xpipe, and a couple other bolt ons. I cant decide what nitrous kit to go with, im leaning toward the TNT F2. Im also trying to decide if i should get head studs or not. What kind of RWHP and Times can i expect, and what nitrous kit should i get.
Re: The making of a low 10 second street car.
just a few weeks ago i went 10.97 cam only with a tnt f2 100 shot...i figure with some cold weather,some heads, and upgraded fuel system for a larger shot low tens- high nines are possible.
joey
joey
jpjbc can you e mail me at somewinsomewine@aol.com i neeed to ask you a couple a q's about your combo if you dont care thanks man
joey
joey
98tata you have mail...jf ws6 im not sure if anyone has made it nines with the stock bottom end or not i know of a few that went 10.1xs with the stock botoom end...with a little luck and a good tune i think it can be done...i hope to find out this winter...
Actually, I'm suprised nobody has done it yet....
Restricted User
If the NXL kit ever comes out I will try my pistons off to get it! But then again, if "If" was a fifth, we'd all be fugged up!
I believe the GM gaskets will be fine, get the ARP studs if you plan on taking the heads off a few times. I got the ARP head bolts, ARP PN# 134-3609
I heard you have to pull the motor to take the heads off if you use studs... is this true... said because you have to lift them up over the studs...i will have the motor out of the car for the head install... but if i ever blow a head gasket (which i know i probably will) i dont want to have to pull the motor again.
No, that's not true. There are several people on the board here who use head studs and have been able to take the heads off without taking the motor out of the car.
if your trying to get into the 9's on a stock bottom end, its gona come down to how well the nitrous is distributed betwene the cylender. That being said I would either go with the NOS nozzel kit or something else that dosent spray infront of the throtle body.
I am going for 9's next year, but with an ARE 346 and a direct port nitrous kit. I'm afraid of leaning out the rear cylinders shooting for a 9 with my TNT Power Ring.
Im not planning on 9's on a stock bottom end... im planning on 10's I plan on 9's next year after i get a forged bottom end of some sort.
You could make LS1 history....or just make really cool holes in the side of your block, and oil down the track.
I think it would be cool to try, but I dont want to lose a perfectly good motor doing it.
Restricted User
I think I might like to try, once I get the forged bottom end waiting on the sideliens, and a spare block, NXL. I think my trans and rear will go first! But, I am wanting 10's, mid to hi 10's n stock bottom at least.
