MS4 Shiftpoints
Old 04-23-2008, 04:37 AM
Racer
UL LOSE's Avatar
Default MS4 Shiftpoints
What are you guys with the MS4 cam shifting at? I think it peaks at 6400rpms. Is that accurate? Im thinkn of shifting at 6700 or 6900. What do you guys think?
Old 04-23-2008, 04:43 AM
COD02SS's Avatar
Stock shortblock? Stay under 6500 if you want the motor to last.
Old 04-23-2008, 05:44 AM
s346k's Avatar
put the car on a dyno and then see. i'd guess somewhere between 6,800-7,000.
Old 04-23-2008, 05:57 AM
PONTIAC SLP's Avatar
when i had before the MS4 with nitrous i shifting about 6800 to 7000
Old 04-23-2008, 08:10 AM
james562's Avatar
Take it to the track and try setting it to shift @6700, 6800, and 6900 Whichever nets you the best ET(assuming your consistant) and MPH is where you should leave it
My buddy had the MS4 and PRC LS6 STG 1 heads in his 4400 stalled 2000 Vette and ran 11.2@119-121 (1.57-1.59 60") in +2000DA. He set the tranny to shift at 6400 because the car wouldnt make the actual shift till ~6800
From what he showed me 6800-6900 is about where you want it testing and tuning will give you the best possible ET
Old 04-23-2008, 11:33 AM
gsxr1k2's Avatar
Dont know if this will help you or not but Matt at TSP recommended I set my rev limiter at 6700.
Old 04-23-2008, 11:58 PM
Racer
UL LOSE's Avatar
I dont have the software to change the shiftpoints myself so I have to get my friend to set them and put a tune in it and then go to the track. So it will be hard for me to change them very often. Was looking to just get them set once and be done with it. Thinking of setting the rev limiter at 7000.
The motor will be bone stock except for ms4 cam,921 springs,7.400 pushrods and 42lb injectors. Im thinkn of setting the shiftpoints at 6700. Would like to get the most out of it by keeping it in the power band though so if it pulls all the way to 6900 I'd rather shift there. So what do you guys think? Shift at 6700 or 6900?
Old 04-24-2008, 01:29 PM
greinder03's Avatar
i dont know much about springs, but will those 921 springs handle the ms4?
Old 04-24-2008, 01:39 PM
BlackSS2001's Avatar
It keeps going
Old 04-24-2008, 10:55 PM
Racer
UL LOSE's Avatar
What rpm does it peak at? Its hard to tell from that chart. I think Imma do 6700.
Old 04-25-2008, 12:12 AM
99mongooSS's Avatar
I was shifting at 7100, And probably will again.
Old 04-25-2008, 09:20 AM
I'm not sure. as you can see in the dyno it didnt even start droping. I didnt want to push my stock bottom end past 6500. I had a 3 1/2 hr drive back home with the car so I didnt want to take any chances. I was shifting at 6800 last year but I had McCord lower my rev limiter to 6500 just to be safe.
I have seen people pushing 7200 though.
Old 04-26-2008, 06:04 PM
Racer
UL LOSE's Avatar
I guess Imma try 6700 and see what it runs at the track and if Im not satisfied Ill up it to 6900. As long as it has a good trap speed shifting at 6700 Id rather leave it there tho.
