lifters
Old 04-23-2008, 07:21 AM
2002WS6TA-LS1's Avatar
Angry lifters
I have questions about diagnosis of lifter problems.
I brought my 2002 ws6 TA to the dealer with lifter noise that goes away
after warm up.
they are telling me it is the o-ring in the oil pick up tube.
I have a couple problems with this.
1 if the oil lifters are draining down they are going to get scored by the cam
2 the cams are going to get scored by the lifters
3 the lifters are suppose to ride on a film of oil and S/B preloaded correctly
4 the tsb was never sent to me for this condition.
5 i bought the car new.
6 why should i pay for this when it is the factories mistake
7 if i let them do this and they don't correct the results of there mistake i am
going to still have problems.
8 gm decided to change the location of the oil pump and are having problems
with this decision why should I have to pay for there mistake.
9 there is only 25,000 miles on the motor.
10 how can i get a gm rep to look into this problem?
if there are more people with this problem please write back
Old 04-23-2008, 08:45 AM
slowec's Avatar
Thats easy. talk to the service manager and make him promise if it does not fix the problem , You won't pay for a mis-diagnosis and a repair you didn't need. There was a problem with the oil pump o-ring being cut, But very few were actually found to be damaged.
I did many of them years ago as a dealer tech. good luck.
Old 04-23-2008, 09:26 AM
SOMbitch's Avatar
I thought if it was the O-ring the tick would not go away
Old 04-23-2008, 10:31 AM
black01_WS6's Avatar
are you sure it is the lifters and not piston slap?
Old 04-23-2008, 10:52 AM
SOMbitch's Avatar
A real possibility. I have heard LS motors where the piston slap won't totally go away after warm up. My 5.3 Z-71 has piston slap at start up but sometimes it will have a faint random tick too. 177K and going strong though
Old 04-23-2008, 10:56 AM
vettenuts's Avatar
Yours is an 02, you have the newer pistons. The tick could be from carbon build-up, especially if you don't drive it hard. I had this problem with my 02 after a long trip where most driving was in 6th gear. I now use something to prevent the carbon build-up.
Why not try getting rid of the carbon first. Its cheap and if it doesn't work you are only out a few bucks. The torn o-ring would have shown itself long before now.
