First 1/8 mile results w new setup
after installing the cam, heads, intake, and stall converter, this is my first run at the track. For some reason they were only running 1/8 mile that night at the track. I had 17" BFG dr's and no other traction mods so my 60's weren't that good. So tell me what you guys think. Here are the results:
1st run
60 FT 1.7757
330 FT 5.2027
1/8 ET 7.9737
1/8 MPH 89.45
2nd run
60 FT 1.8829
330 FT 5.1739
1/8 ET 7.9012
1/8 MPH 90.38
1st run
60 FT 1.7757
330 FT 5.2027
1/8 ET 7.9737
1/8 MPH 89.45
2nd run
60 FT 1.8829
330 FT 5.1739
1/8 ET 7.9012
1/8 MPH 90.38
i got a stock 98 ta with no tuning only hpertech longtubes borla exhaust tci converter and 373 gears that runs that u got something bad wrong dont know what u got but it aint rite whatever it is also had a bonestock convertable that run 8.28 everthing stock down to the tires
x2, 1/8 mile is all about 60's. Im assuming the car is tuned? What #'s are you putting down. Enough converter for your cam? We need some more info. My cam only, stock shitty '99 headed car went 7.2X the other day, and Im still tuning on it.
yeah the car is tuned. Here my exact mods:
MS3 cam (237/242 .603 .609) 112 lsa
CNC ported LS6 heads
LS6 intake
ported TB
42 lb injectors
lid
tci ssf 3500 stall converter
Headers, off road y and exhaust
sfc's
BFG dr's
I see ppl put hard to believe times and et's on here all day. but when I go to the track my car runs right where I think it should for the traction i'm getting and compared to the other cars in this area. I just ordered QA1 coilovers for the front and relocation brackets for the rear. this shud def help my 60 foot times.
LS6 intake
ported TB
42 lb injectors
lid
sfc's
BFG dr's
i believe your setup should be where in the 94-95 mph range in the 1/8, and 60' somewhere in the low 1.7 fairly easily. that stall is mismatched for that cam, but it shouldn't affect the mph all that much. i'd consider another tune, or simply checking the car over for other problems, it should definately make more power than that.
While getting my car tuned after all these big mods the tuner said my o2 sensors weren't reading most of the time, will replacing these help my car?
Dont be too upset man I just ran my car today tr224 vig 3200 Patriot stage2 heads 3.73's DRs tpis 90/90.
60 1.624
330 4.804
1/8 7.503
mph 91.15
100 9.839
1/4 11.802
mph 115.28.
Now I need a new rear. but a bigger cam is in the futuer too.
60 1.624
330 4.804
1/8 7.503
mph 91.15
100 9.839
1/4 11.802
mph 115.28.
i'll agree that the mph and et seem a little off but you need to give more info so guys can help you out. what was the weather(da)? did you hit the rev limiter or pedal it at all? fwiw my car will vary as much as 3 tenths and 2 to 3 mph based on weather alone. every car is different but i would expect to see at least 93mph in the 1/8 with that h/c setup. if your tuner said your o2's weren't switching that isn't a good thing either.
