Transmission Mount Help M6
Hey all just have a question ,I just installed a performance mount on my formula m6 and I took it out for a spin, but now I am have trouble going into 3rd gear and it is making some weird sounds. I looked underneath and everthing looks ok didnt miss any bolts or anything,What do you guys think could have happened? did he transmission shift or something, and what can I do to fix the problem? Thanks for any help.
well when I turn the car off it makes like a chattering sound, and as for the bolts I tightened the **** out of them,but I will recheck them . The mount I bought was a prothane transmission mount .
1 Post
did u use the supplied hardware?? maybe the stud came loose off of the mount? did u use a jack to keep the tranny in place while you removed the mount? you can also try removing what you have done, maybe u might find your problem
