Transmission Mount Help M6
Old 04-29-2008, 09:42 PM
guns77's Avatar
Unhappy Transmission Mount Help M6
Hey all just have a question ,I just installed a performance mount on my formula m6 and I took it out for a spin, but now I am have trouble going into 3rd gear and it is making some weird sounds. I looked underneath and everthing looks ok didnt miss any bolts or anything,What do you guys think could have happened? did he transmission shift or something, and what can I do to fix the problem? Thanks for any help.
Old 04-29-2008, 11:33 PM
99z28monster's Avatar
make sure you have it bolted in all the way. What kinda noise is it making?
Old 04-30-2008, 08:03 AM
guns77's Avatar
well when I turn the car off it makes like a chattering sound, and as for the bolts I tightened the **** out of them,but I will recheck them . The mount I bought was a prothane transmission mount .
Old 04-30-2008, 06:46 PM
guns77's Avatar
Come on guys no one has any advise on this , Has no one else run into this problem.I find that hard to believe, please some help.
Old 04-30-2008, 10:16 PM
ae13291's Avatar
did u use the supplied hardware?? maybe the stud came loose off of the mount? did u use a jack to keep the tranny in place while you removed the mount? you can also try removing what you have done, maybe u might find your problem
