car won't idle after hot cam install
Old 08-04-2003, 10:19 PM
meanls1's Avatar
Default car won't idle after hot cam install
I installed the hot cam this weekend and it went fairly smooth. The only problem is the car won't idle right. We drilled the throttle plate to .250 still wont idle. I heard something about an idle re-learn or something like that. I don't know what else to do accept get the car tuned.
Old 08-04-2003, 10:20 PM
v8maro's Avatar
Default Re: car won't idle after hot cam install
M6 or A4?
I *sometimes* have to rev to about 1500, and lightly let off the gas and it'lll learn it's self out.
-Steve
Old 08-04-2003, 10:24 PM
meanls1's Avatar
A4 with a Yank st3500. I tried that but after a while it dies.
Old 08-05-2003, 08:22 AM
00 Firehawk's Avatar
Clint, do the PCM reset and see if it learns itself out. If not drill the hole bigger, I had to.
Old 08-05-2003, 08:39 AM
Raven's Avatar
Your best bet to get the car to stop surging at idle is to have the pcm programming adjusted by someone (like a shop). I wouldn't make the hole in the throttle blade any bigger until you have someone who knows how to do that sort of programming with LS1 edit have a chance at resolving it. You'll proilly be able to squeeze a few extra HP out of your setup with some pcm re-tuning too. good luck
Old 08-05-2003, 09:23 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Get that sucker tuned!
Old 08-05-2003, 05:01 PM
meanls1's Avatar
It's going in tomorrow for tuning........Thanks for the input guys.
Old 08-05-2003, 06:28 PM
Nagash01WS6's Avatar
heh... Tuning is you're best bet.
I just pulled mine out.
Gettin the new cam tuned on Friday.
Sad enough it idles better on the hotcam tuning than the hotcam.
Quick Reply: car won't idle after hot cam install
