Having some major mechanical problems that can't seem to be solved!
Old 05-05-2008, 09:36 AM
blu1's Avatar
Default Having some major mechanical problems that can't seem to be solved!
Copied and pasted from another forum.
Originally Posted by Blu
http://forums.corvetteforum.com/show....php?t=2009265
There is my original thread to review. As of now the car is still at the shop, wiring schematics have been went through, plugs checked, sensors checked to my knowledge and still no cause has been established and my damn car still won't start.
Any guru's have any possible ideas? Help please!!!
Old 05-05-2008, 12:08 PM
ss.slp.ls1's Avatar
As others have said, first check to see that all sensors are hooked up properly, second, take it back to where you got it tuned.
Old 05-05-2008, 12:38 PM
blu1's Avatar
it is there now but they haven't been able to pinpoint the issue yet.
Old 05-05-2008, 12:44 PM
ss.slp.ls1's Avatar
Well I hope its a reputable tunning shop, otherwise you will be paying $ for a lot of misdiagnoses.
Old 05-05-2008, 12:57 PM
blu1's Avatar
its an LS1tech sponsor, def a reputable shop.
Old 05-05-2008, 01:17 PM
TurbopigB4C's Avatar
has a comparable ecu been installed ive seen some wierd stuff being a drivability tech for gm, in corevettes and xlrs they have a problem with static electricity frying pcms and doing something similar to what you got or a loose ground
Old 05-05-2008, 01:23 PM
Also are they using a tech 2 to pull codes and get info? The aftermarket scanners wont pick up the stuff the tech 2 can.
Old 05-05-2008, 01:29 PM
blu1's Avatar
I pulled the codes from the car using the method available. Hold options and press fuel 4 times and it displays the codes.
Old 05-05-2008, 01:50 PM
to accurately diagnose it you will need more than just the codes you need to pull the data values and try and find someone that can get on gm dealerworld service information and get the flowcharts for the codes which will steer you in the right direction step by step i worked at an independent for a while that had both of these but for the most part thats why the dealers make the big bucks because they got this stuff
Old 05-05-2008, 04:44 PM
blu1's Avatar
Car is all fixed, can you believe it was a fuel pump ground that came disconnected? What a relief!
Old 05-05-2008, 04:51 PM
ss.slp.ls1's Avatar
Good to hear.
