how much boost from a 3.2 to a 3.1 pulley?
Old 05-08-2008, 02:21 PM
transdam's Avatar
Default how much boost from a 3.2 to a 3.1 pulley?
3.2 makes 7psi and i what 9psi would a 3.1 or a 3.0 be best on a p1 6 rib setup
Old 05-08-2008, 04:21 PM
v8juice's Avatar
Depending on your exhaust,etc.. a 3.0 should get you close to 9.0psi
Old 05-08-2008, 09:11 PM
transdam's Avatar
thanks for reply just didn't want to go over 9 psi. how much power did yours make at 9psi?
Old 05-09-2008, 05:51 AM
EPP
EPP's Avatar
You will more than likely have belt slippage problems going any smaller than a 3.2 on the pulley. You would be better off finding a larger crank pulley. ASP makes them but they are not cheap. Bob
Old 05-09-2008, 06:52 AM
Rickys S/C Z28's Avatar
i have the 3.2 on there now and like you im making 6.5-7 psi, im going with an 8in crank pulley and hoping for 9-10 psi, ill let you know how it turns out, if you do go with a 3.0 pulley let me know how much slip if any you get please
Old 05-09-2008, 05:09 PM
transdam's Avatar
who sells a bigger crank pulley for the 6rib procharger setup
Old 05-10-2008, 01:02 AM
aps does but it cost like 350-400 buck i have a buddy that can make me one so that what im doing
Old 05-12-2008, 03:03 PM
SKI
SKI's Avatar
That's alot of cash for one pulley.I am thinking of stepping up to 8 rib.
Quick Reply: how much boost from a 3.2 to a 3.1 pulley?
