problem...
Old 05-08-2008, 09:21 PM
97ssCDB's Avatar
Default problem...
So I was switching out the alternator and the wire for the connection on the top broke off and there is not enough wire to reconnect it. Any ideas?
Old 05-09-2008, 02:13 AM
99blancoSS's Avatar
so the wire broke off at the connector is what your saying? If so you just need a pigtail made up for you and you can splice it into the harness. I can get you one, pm me if your interested. OR call around to some local shops and see who can make on up for you. It literally takes 1 minute to make. Even a dealer could handle it.
Old 05-09-2008, 09:03 AM
thunderstruck's Avatar
you can pull that terminal out of the weather pack and unclamp the terminal from the original wire then put a longer wire back in and clamp it back
