How To Wire Tach??? Autometer Aftermarket 5"
i needed an aftermarket tach for my car because i will be spinning higher RPM's when i put my cam in. my buddy gave me a 5" Autometer sport comp with a shiftlight out of his 69' camaro(has distributor). my question is how can i wire this up to my 2002 camaro LS1 with a plug on coil igition? do i need some kind of adapter?(if so,where can i find one for cheap?) i have heard something about putting it in 4cyl mode?
Location: Your girl's back door giving her the long stroke while you're at work
yup the green wire off the tach goes to PIN #10 on the PCM. Red to a key on power source, black to a ground and white is for the light inside the tach(i used the gauge fuse inside the car)
