slp lin loc?
slp lin loc?
just curious if i should be just seeing the rf loc up verses both tires.. im runing the line from lin loc to rf spot on abs box. just rf losc no left is this correct if so sucks cars goes sideways every burnout unless i dont use it. could it be a bleeding issue?
Damn man learn how to use spell check or the English language first. If you do not have the directions from SLP you can get them off their web site. But there is one line that runs form the master cylinder to the ABS block that you have to change out. The new like runs from the master cylinder to the line lock and then the other line goes from the line lock to the ABS block. If everything is hooked up right then yes it will most likely be a bleeding problem.
well figured it out finally when i did new motor combo i switched the lines at the abs box left to right and it was locing rear and front up lol. i new it worked before i did the swap..i guess we all screw up a bit.
