does it look saggy to you?
Old 05-12-2008, 12:43 PM
TUCKZ28SS's Avatar
Default does it look saggy to you?
It has SLP lowering springs and bilsteins. I think the *** end looks good, but the front end is a little high.
Old 05-12-2008, 01:07 PM
doc420's Avatar
Stop using my pics!!! Just joking man. I still go back and forth about selling her.
Old 05-13-2008, 02:18 PM
TUCKZ28SS's Avatar
Yeah my camera took a **** on me!! I put in clear corners, and have a billet grille on the way. manta hood should be painted soon too!!
Old 05-13-2008, 02:19 PM
TUCKZ28SS's Avatar
Is it me, or does the front look lifted to you Doc?
Old 05-13-2008, 02:22 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
doesn't even look lowered , really.????
Old 05-13-2008, 02:49 PM
1FasstWS6's Avatar
looks to be sagging a bit, try some GTO spring blockers or something to keep the back springs firmer since the front is suppose to be lower.. unless it is and i have really bad view. haha
Old 05-13-2008, 08:25 PM
TUCKZ28SS's Avatar
no the back is lower and the front almost looks like a stock height. The back sags even more now. I wish I had an updated pic. Where do I get the spring blockers from?
Old 05-13-2008, 11:13 PM
1FasstWS6's Avatar
Back when the GTO's 1st came out dealerships had them on the cars and were taken off and pretty much set aside or disposed.. alot of the grandprixers are selling them on clubgp, but i would look into your spring setup 1st to make sure you have everything right. you have extra weight of anything in the back? only thing i can think somehow switched fronts/rears.. haha
Old 05-13-2008, 11:15 PM
1FasstWS6's Avatar
edit: if you can get a better pic that would help alot.
Old 05-14-2008, 08:41 AM
doc420's Avatar
It is definately lower than stock. I've had it lined up against an SS and Z28 without the bilstein option and it was lower. If I kept the car I would have replaced the SLP LT's for some kooks and lower it about a 1.5" and it would look good especially with an SS grille or a billet grille.
Old 05-14-2008, 08:42 AM
doc420's Avatar
By the time you move down here hopefully I'll have my Z06 by then. Give me a shout if you need any help with anything moving down here.
Old 05-14-2008, 10:34 AM
djjab57's Avatar
The rear looks great looks like you need to drop the front a little Very CLEAN car
Old 05-14-2008, 12:36 PM
TUCKZ28SS's Avatar
thanks, I am thinking about a pro kit set up. Doc I was hired yesterday by US Customs for a federal agent job in Buffalo, so the move down has been postponed a bit. UUGGGHHHH another NY winter.
Old 05-14-2008, 02:41 PM
doc420's Avatar
Yeah I remember you talking about that when you came down to pick up the car. Just tell them no thanks and move down here to Charlotte!!!
Old 05-14-2008, 07:26 PM
TUCKZ28SS's Avatar
believe me man, I was already out the door when they called. I was really looking forward to hot summer nights at Lowes Motorspeedway, mm mm mm, I will get there hopefully in a year. Keep that beer cold!!
Old 05-14-2008, 08:12 PM
BMR Tech's Avatar
Just an option I do sell just the fronts part # SP002 they list for $125.95
http://www.bmrfabrication.com/F-bodySuspension.htm
They are about a 1.25 inch drop which I think would correct the stance on your car.
Old 05-19-2008, 11:55 AM
lt1noob's Avatar
thats what she said
the back looks good, dont know if its really sag but the fronts wayyyyyy to high.
Old 05-20-2008, 12:30 AM
Kennedy98z28's Avatar
Mine is the same way.
Quick Reply: does it look saggy to you?
