Uncommon exhaust setup. Input needed
I posted a thread similar to this a while back but I would like to get some more input from you guys before I decide to go this route. I have decided that I would like to eliminate the X,H or Y pipe from my setup. Rather I would like to just run two Borla XR-1's off of each header collector and dump them after that. The reason that I want to do this is because I will be running a rather large H/C setup (in sig) as well as a large converter (4000 to 4200). I want an exhaust setup that will have optimum breathing at higher RPM's. I don't care if I loose power down low because I won't ever be in that band with the a stall that large. Here's a picture of what I'm thinking, what are you guys' opinions regarding this setup? Also, I know that it won't fit exactly this way, I'll need to lower them a little with the mufflers being so large, so disregard that.
Thanks for the input.
