Overheating issue after LS6 intake?
I was told by someone that by using the coolant plugs to plug the rear coolant lines, causes the car to overheat.
is this true? and if so, should i just use another front coolant crossover pipe?
So from what im understanding you can't just install an LS6 and be done with it? I thought for an LS1 all you have to do is trim the bottom/new coolant lines, and thats it. Again im still with the LS1 intake, so this information can help me in the future.
-Joel
-Joel
From what i understand it was called 'steam vent' and was to go back to the TB, then to the coolant tank which sat higher. If you were getting air somewhere in the system this is how it would bleed out. Otherwise you may have an air pocket somewhere in the system. This is just what i have read and what i understood from it. I ran mine to my radiator in my swap, didnt know i could block it off.
-Joel
